audacity-macos-3.0.0-dmg Virustotal warning
After audacity-macos-3.0.0.dmg download I check this file with Virustotal
MaxSecure tells Trojan.Malware.121218.susgen
SHA 256 Checksum is ident
https://www.virustotal.com/gui/file/f769a9e8c0f2352171933339681616ddab43ca6d7b688918e5af8bd1382a0fad/detection
Greetings
Fred
Thanks for the report.
I have notified maxsecureantivirus of this false positive.
Hi Steve
Just checked and the dmg is still alerting by MaxSecure.
Can you tell us what is causing the alert?
Thanks
odododododod
What can I tell you?
57 anti-virus checkers, including all of the big names say that it’s safe. They are right.
One that I’ve never heard of disagrees. Max Secure has had their own problems with false positives in the past: https://superuser.com/questions/89253/is-max-secure-software-malware
Thanks! :exclamation:
Interesting - this is the VirusTotal result for the Max Secure website: https://www.virustotal.com/gui/url/c534537214e273b5a038c8af651b893dd28694f139debd7408ca2394b432b7ff/detection
2 security vendors flagged this URL as malicious
Typical scam AV vendor. They try to sell a subscription, adding a “no questions asked” refund if you don’t like it. Of course, no refunds, even if you insist.
I’ve notified VT.
I get the warning about a Trojan for the latest Audacity download
sha 256 checksum matches
It’s back down to just one warning. Note that the warning comes from a little known anti-virus that has their own problems (their website URL on VirusTotal).
I think it’s safe to say that MaxSecure is still throwing a false positive (which was reported to them in March last year!)
