So in monterey the option to open the app in low resolution is gone and i had to change the info.plist to bring it back and now audacity is snappier. The menu though its low resolution as normally should be after the tweak. Is it so difficult to code the program to run in high resolution on macOS normally?
So the developers are porting the Audacity UI from wxWidgets to QT, which migration is scheduled for 4.0. Expect to have little tweaking on the UI before that time.
Oh thats good news, finally!
