hi, i’ve got the message that a plugin that use’s java and audacity isn’t recognizing java’s path’s. can you tell me why?
Audacity_dbgrpt-8676-20160712T105258.zip (83.9 KB)
I’m not a developer but as far as I know, Audacity has no relationship to Java.
Do you have a Java plug-in that’s supposed to work with Audacity?
yes i’ve got a java plug-in that’s suppose to work.
these are the ones that i’m have trouble with audicity. before they worked on audacity. http://www.pitchtech.ch/Plugins/
Those plugins work for me in Audacity in 2.1.3-alpha on Windows 10, so it is a problem with your JAVA environment.
Also make sure you copied the plugins’ three .jar files into the folder where you installed the plugins.
ok i’ll try that
