I’m using Audacity in Manjaro’s “community” repo, and come across this problem too. The version I’m using is 2.3.1 (or in pacman’s naming style, 1:2.3.1-1).
If if can be helpful, my log in running audacity is:
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-midigate>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-midigate.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-midigate.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-params>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-params.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-params.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-amp>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-amp.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-amp.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-fifths>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-fifths.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-fifths.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-scope#Mono>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-scope.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-scope.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-scope#Stereo>
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-metro>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-metro.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-metro.lv2/ (ignored)
lilv_world_add_plugin(): warning: Duplicate plugin <http://lv2plug.in/plugins/eg-sampler>
lilv_world_add_plugin(): warning: ... found in file:///usr/lib/lv2/eg-sampler.lv2/
lilv_world_add_plugin(): warning: ... and file:///usr/lib64/lv2/eg-sampler.lv2/ (ignored)
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-midigate>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-params>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-amp>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-fifths>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-scope#Mono>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-scope#Stereo>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-metro>
lilv_world_add_plugin(): warning: Reloading plugin <http://lv2plug.in/plugins/eg-sampler>
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:869:(find_matching_chmap) Found no matching channel map
connect(2) call to /dev/shm/jack-1000/default/jack_0 failed (err=No such file or directory)
attempt to connect to server failed
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
23:32:47: Debug: ScreenToClient cannot work when toplevel window is not shown
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1904
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2171
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2840
ALSA lib pcm_dsnoop.c:638:(snd_pcm_dsnoop_open) unable to open slave
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
23:32:54: Debug: ScreenToClient cannot work when toplevel window is not shown
23:32:54: Debug: ClientToScreen cannot work when toplevel window is not shown
23:32:54: Debug: Unrecognized accel key 'backspace', accel string ignored.
23:32:54: Debug: Unrecognized accel key 'numpad_enter', accel string ignored.
(audacity:5101): Gtk-WARNING **: 23:32:56.966: gtk_window_present_with_time() should not be called with 0, or GDK_CURRENT_TIME as a timestamp, the timestamp should instead be gathered at the time the user initiated the request for the window to be shown
*** BUG ***
In pixman_region32_init_rect: Invalid rectangle passed
Set a breakpoint on '_pixman_log_error' to debug
