Audacity freezing every time I click/tab off it or it generates a new window.
Audacity version: 3.0.2
What I’m trying to do: I’m trying to use audacity to record voiceover.
Generate Support Data: I can’t because Audacity freezes every time I try to do so.
I’ve been using Audacity 2.4.2 for awhile, but sometimes it would stop recording randomly with an error message saying it was taking up too many resources. I finally got fed up with that and checked to see if updating it would help. Now I can’t do anything with Audacity at all because it completely freezes up whenever I alt tab or click off the audacity window.
Do you use Japanese Windows, or a Japanese keyboard (or other non-Latin character set)?
I do, actually. I have some VNs downloaded that need my system location and keyboard to be in Japanese. Is that what’s causing the issue?
Not directly. The problem is caused by a bug in a recent Windows update affecting the IME (Input Method Editor). There’s some information about it here: https://support.microsoft.com/en-us/topic/you-might-have-issues-on-windows-10-version-20h2-and-windows-10-version-2004-when-using-some-microsoft-imes-63696506-47d2-9997-0b72-41a68e328692
Microsoft claim to have fixed the issue, but I don’t know if that means that it will be automatically fixed by fully updating Windows, or whether it is necessary to roll-back the bad update first, or manually apply the fixes mentioned in that article.
Do you know when the problem started?
Are you able to correlate that with a specific Windows update?
Well, like I said, I had been using 2.4.2 until today. I was recording and it got cut off by a message saying it was taking up too much system resources, which prompted me to update to 3.0.2.
I shifted my keyboard from Japanese to English and the problem seems to be resolved.
Super. Thanks for the update.
