Audacity flickers but does not record
My Audacity program flickers but does not record - the sound is from a Marantz amplifier RX 173 AV and is plugged into the line in portal.
We need more information…
What’s flickering? Are you talking about the dB meters? What are the meters reading?
Does the cursor move when you click Record? Do you get a flat line instead of a waveform?
…plugged into the line in portal.
Connected to tape-out or line-out from the amplifier? Are you sure you’ve got a signal coming out? Do you have anything else to plug-into to check that? (Amplified computer speakers, or your TV, etc.?)
I assume you’re using a desktop/tower computer with a regular soundcard? (Line-in should be color-coded blue.)
Have you selected Line-in as your [u]Recording Device[/u]?
