"Audacity failed to read a file in C" Error frequency?
Just had this happen to me :astonished: So awful, I’m curious as to how often this happens? I hate that I’m now mistrustful :frowning:
If you work on projects that are saved to an external drive, it happens a lot.
If you work on projects that are saved on an internal drive, it hardly ever happens (unless you run out of disk space).
Also, your .aup3 project file may be damaged. See: https://forum.audacityteam.org/t/audacity-failed-to-read-from-a-file-in-c/65141/1
