Audacity error message
I just downloaded the Audacity 2.x on my windows 7 pc and all I get is this message and I have no clue what to do. Can you please help me?
Audacity error message:
Error while opening sound device. Please check the input device
settings and the project sample rate.
See this Frequently Asked Question:
http://manual.audacityteam.org/o/man/faq_errors.html#sound_device .
I went there but there was no help because I had tryed that before I asked this question. I did discover however that there is no ‘input device found’. So how do I solve that problem?
What sort of input device are you trying to record from? A microphone plugged into your computer sound card?
Check in the Windows Sound Control Panel to see if the device that you wish to record from is enabled.
I keep at it and finely got things working, it seems that somewhere in the computer system that the sterio thing was muted. Thank you for your help
