HeidiV
April 26, 2022, 12:14am
1
Hello,
How do I get the Audacity effects VST, Nyquist, FFMpeg & Lame from here:
https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_mac_os_x.html#vst_install
to my Audacity platform?
Some of them have over 50 pages of effects??? I can’t load them individually, that would take far too much time. I need some help/confused.
Please help.
Heidi
HeidiV
April 26, 2022, 12:15am
2
PS: I’m iMac Monetery 12.3.1
April 26, 2022, 12:17am
3
Which effects do you need? Audacity ships with a good selection of effects by default.
HeidiV
April 26, 2022, 12:23am
4
Hi there, thank you for the reply.
She states
“Load them ALL> VST, Nyquist, FFMpeg & Lame. You need the effects (VST & Nyquist) plug-ins to be able to edit (compression, EQ, limiters, etc.), and you need the LADSPA (Lame & FFmpeg) to be able to export files properly. The FFmpeg library allows you to export in multiple raw file formats, while the Lame library allows you to export to mp3. You NEED these for auditions.”
Some of the lists are ridiculously long.
April 26, 2022, 1:07am
5
Built in Compressor: https://manual.audacityteam.org/man/compressor.html
Built in Graphic EQ: https://manual.audacityteam.org/man/graphic_eq.html
Another built-in EQ: https://manual.audacityteam.org/man/filter_curve_eq.html
Yet another built-in EQ: https://manual.audacityteam.org/man/bass_and_treble.html
Built in Limiter: https://manual.audacityteam.org/man/limiter.html
List of built in effects: https://manual.audacityteam.org/man/index_of_effects_generators_and_analyzers.html
LADSPA effects are ancient. I would not recommend them.
Lame is now built in by default.
FFmpeg is only required to support importing / exporting proprietary formats. Audacity has built in support for WAV. AIFF, MP3, OGG, and FLAC.
HeidiV
April 26, 2022, 1:13am
6
Thank you Steve, very helpful!
Do I simply click the links you’ve provided under “compression, EQ, Limiters etc”?
FFMpeg - will I be able to export to VO client and their platforms?
Truly,
