I’m new to Audacity and installed the V4 today. After open it, I’ve been asked to choose the design etc. and then - it quitted. I’ve tried it several times including restart. I didn’t read anything in the “install -How-to”, that I have to to anything else. So, I appreciate any help! Thanks in forward!
Ah - here’s the crash-report - perhaps it helps you …:
Translated Report (Full Report Below)
Process: audacity [1752]
Path: /Applications/Audacity 4.app/Contents/MacOS/audacity
Identifier: org.audacityteam.audacity4
Version: 4.0.0 (262451556)
Code Type: X86-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: org.audacityteam.audacity4 [1335]
User ID: 501
Date/Time: 2026-09-20 18:17:55.4152 +0200
Launch Time: 2026-09-20 18:17:41.7572 +0200
Hardware Model: MacBookPro16,1
OS Version: macOS 26.7 (25G229)
Release Type: User
Bridge OS Version: 11.0 (24P6005)
Crash Reporter Key: A776E1C6-FF1F-2811-24F7-986E99E51D69
Incident Identifier: DE2CC284-8374-4300-96E5-F27BDC335D0C
Time Awake Since Boot: 530 seconds
System Integrity Protection: enabled
Triggered by Thread: 0 main, Dispatch Queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x0000000000000018
Exception Codes: 0x0000000000000001, 0x0000000000000018
Termination Reason: Namespace SIGNAL, Code 11, Segmentation fault: 11
Terminating Process: exc handler [1752]
VM Region Info: 0x18 is not in any region. Bytes before following region: 4503404520
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 10c6c8000-10e9db000 [ 35.1M] r-x/r-x SM=COW /Applications/Audacity 4.app/Contents/MacOS/audacity
Thread 0 Crashed:: main Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x7ff805c8b09d objc_msgSend + 29
1 libqcocoa.dylib 0x111bc98e5 0x111ba6000 + 145637
2 libqcocoa.dylib 0x111bca59e 0x111ba6000 + 148894
3 QtLabsPlatform 0x12a46a25c 0x12a450000 + 107100
4 QtLabsPlatform 0x12a464289 0x12a450000 + 82569
5 QtLabsPlatform 0x12a464fab 0x12a450000 + 85931
6 QtLabsPlatform 0x12a46653a 0x12a450000 + 91450
7 QtQml 0x111954585 QQmlProxyMetaObject::metaCall(QObject*, QMetaObject::Call, int, void**) + 469
8 QtQml 0x1117e3a63 0x11168d000 + 1403491
9 QtQml 0x1117e101a QV4::QObjectMethod::callPrecise(QQmlObjectOrGadget const&, QQmlPropertyData const&, QV4::ExecutionEngine*, QV4::CallData*, QMetaObject::Call) + 1130
10 QtQml 0x1117e83ed QV4::QObjectMethod::callInternal(QV4::Value const*, QV4::Value const*, int) const + 2541
11 QtQml 0x11180a16f QV4::Runtime::CallQmlContextPropertyLookup::call(QV4::ExecutionEngine*, unsigned int, QV4::Value*, int) + 159
12 ??? 0x114fd64d0 ???
13 QtQml 0x111847687 0x11168d000 + 1812103
14 QtQml 0x11179d69f 0x11168d000 + 1115807
15 QtQml 0x11180a16f QV4::Runtime::CallQmlContextPropertyLookup::call(QV4::ExecutionEngine*, unsigned int, QV4::Value*, int) + 159
16 ??? 0x12a06006b ???
17 QtQml 0x111847687 0x11168d000 + 1812103
18 QtQml 0x111795805 0x11168d000 + 1083397
19 QtQml 0x111794f7d QV4::Function::call(QObject*, void**, QMetaType const*, int, QV4::ExecutionContext*) + 701
20 QtQml 0x1118ecc6e QQmlJavaScriptExpression::evaluate(void**, QMetaType const*, int) + 318
21 QtQml 0x11189175f QQmlBoundSignalExpression::evaluate(void**) + 447
22 QtQml 0x11189205d 0x11168d000 + 2117725
23 QtQml 0x111913969 QQmlNotifier::emitNotify(QQmlNotifierEndpoint*, void**) + 649
24 QtCore 0x112f67340 0x112e77000 + 983872
25 QtCore 0x112f678f4 0x112e77000 + 985332
26 libqcocoa.dylib 0x111bd4c50 0x111ba6000 + 191568
27 AppKit 0x7ff80ab2c741 -[NSMenu _sendMenuOpeningNotification:] + 212
28 AppKit 0x7ff80ab2c627 -[NSMenu _sendAndRecordMenuOpeningNotification] + 36
29 AppKit 0x7ff80ab26e72 __27-[NSMenu _simulateOpening:]_block_invoke + 146
30 AppKit 0x7ff80ab268b7 -[NSMenu _forEachLinkedMenu:] + 72
31 AppKit 0x7ff80ab26dda -[NSMenu _simulateOpening:] + 93
32 AppKit 0x7ff80aa3e0c3 -[NSMenu(Accessibility) _openForInspection:] + 311
33 AppKit 0x7ff80aa3e963 -[NSMenu(Accessibility) _accessibilityArrayAttributeCount:] + 243
34 AppKit 0x7ff80aa3e784 -[NSMenu(Accessibility) accessibilityArrayAttributeCount:] + 54
35 AppKit 0x7ff80a856a3b -[NSObject(NSAccessibilityInternal) _accessibilityArrayAttributeValues:index:maxCount:clientError:] + 148
36 AppKit 0x7ff80a859d7a CopyAttributeValues + 169
37 HIServices 0x7ff80d490002 _AXXMIGCopyAttributeValues + 435
38 HIServices 0x7ff80d4b0786 _XCopyAttributeValues + 451
39 HIServices 0x7ff80d470717 mshMIGPerform + 192
40 CoreFoundation 0x7ff8061ada9d CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION + 41
41 CoreFoundation 0x7ff8061ad9df __CFRunLoopDoSource1 + 538
42 CoreFoundation 0x7ff8061ac64d __CFRunLoopRun + 2623
43 CoreFoundation 0x7ff806274367 _CFRunLoopRunSpecificWithOptions + 496
44 HIToolbox 0x7ff812efab8b RunCurrentEventLoopInMode + 283
45 HIToolbox 0x7ff812efdc4d ReceiveNextEventCommon + 599
46 HIToolbox 0x7ff8130860ca _BlockUntilNextEventMatchingListInMode + 37
47 AppKit 0x7ff80a737f94 _DPSBlockUntilNextEventMatchingListInMode + 172
48 AppKit 0x7ff80a02d9c5 _DPSNextEvent + 800
49 AppKit 0x7ff80acdbe7b -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1265
50 AppKit 0x7ff80acdb951 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:] + 67
51 libqcocoa.dylib 0x111bbd8da 0x111ba6000 + 96474
52 QtCore 0x112f1b026 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 550
53 QtCore 0x112f11a5b QCoreApplication::exec() + 203
54 audacity 0x10c6d7a50 main + 1536
55 dyld 0x7ff805d0c1c8 start + 3240
Thread 1:
Thread 2:
Thread 3:
Thread 4:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff8060adb4e mach_msg2_trap + 10
1 libsystem_kernel.dylib 0x7ff8060bbf57 mach_msg2_internal + 83
2 libsystem_kernel.dylib 0x7ff8060b4b66 mach_msg_overwrite + 586
3 libsystem_kernel.dylib 0x7ff8060ade56 mach_msg + 19
4 CoreFoundation 0x7ff8061ad6bf __CFRunLoopServiceMachPort + 145
5 CoreFoundation 0x7ff8061ac158 __CFRunLoopRun + 1354
6 CoreFoundation 0x7ff806274367 _CFRunLoopRunSpecificWithOptions + 496
7 AppKit 0x7ff80a17f6a0 _NSEventThread + 158
8 libsystem_pthread.dylib 0x7ff8060f1d49 _pthread_start + 115
9 libsystem_pthread.dylib 0x7ff8060ed82f thread_start + 15
Thread 5:
4 audacity 0x10ce03ce4 crashpad::MachMessageWithDeadline(mach_msg_header_t*, int, unsigned int, unsigned int, unsigned long long, unsigned int, bool) + 388
5 audacity 0x10ce0648e 0x10c6c8000 + 7595150
6 audacity 0x10ce0614c crashpad::MachMessageServer::Run(crashpad::MachMessageServer::Interface*, unsigned int, int, crashpad::MachMessageServer::Persistent, crashpad::MachMessageServer::ReceiveLarge, unsigned int) + 316
7 audacity 0x10cdf8a78 0x10c6c8000 + 7539320
Thread 6:: caulk.messenger.shared:17
0 libsystem_kernel.dylib 0x7ff8060adaca semaphore_wait_trap + 10
1 caulk 0x7ff8129b9b50 caulk::semaphore::timed_wait(double) + 158
2 caulk 0x7ff8129b9a72 caulk::concurrent::details::worker_thread::run() + 30
3 caulk 0x7ff8129b97a6 void* caulk::thread_proxy<std::__1::tuple<caulk:
:attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread*>>(void) + 41
4 libsystem_pthread.dylib 0x7ff8060f1d49 _pthread_start + 115
5 libsystem_pthread.dylib 0x7ff8060ed82f thread_start + 15
Thread 7:: caulk.messenger.shared:high
Thread 8:: caulk::deferred_logger
Thread 9:
Thread 10:
0 libsystem_kernel.dylib 0x7ff8060b05e2 __semwait_signal + 10
1 libsystem_c.dylib 0x7ff805f910d8 nanosleep + 199
2 libc++.1.dylib 0x7ff806011976 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 73
3 audacity 0x10d6662e5 AudioIO::AudioThread(std::__1::atomic&) + 149
4 audacity 0x10d6733a0 0x10c6c8000 + 16429984
5 libsystem_pthread.dylib 0x7ff8060f1d49 _pthread_start + 115
6 libsystem_pthread.dylib 0x7ff8060ed82f thread_start + 15
Thread 11:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff8060b6986 __select + 10
1 CoreFoundation 0x7ff8061d0f57 __CFSocketManager + 664
2 libsystem_pthread.dylib 0x7ff8060f1d49 _pthread_start + 115
3 libsystem_pthread.dylib 0x7ff8060ed82f thread_start + 15
Thread 12:: QQmlThread
0 libsystem_kernel.dylib 0x7ff8060b488a poll + 10
1 QtCore 0x1130c4a1f qt_safe_poll(pollfd*, unsigned int, QDeadlineTimer) + 79
2 QtCore 0x1130c8b0b QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag) + 1147
3 QtCore 0x112f1b026 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 550
4 QtCore 0x113017fc1 QThread::exec() + 353
5 QtCore 0x1130c6425 0x112e77000 + 2421797
6 libsystem_pthread.dylib 0x7ff8060f1d49 _pthread_start + 115
7 libsystem_pthread.dylib 0x7ff8060ed82f thread_start + 15
Thread 13:: QSGRenderThread
0 libsystem_kernel.dylib 0x7ff8060b0712 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff8060f21f7 _pthread_cond_wait + 994
2 QtCore 0x1130cf4db 0x112e77000 + 2458843
3 QtCore 0x1130cf437 QWaitCondition::wait(QMutex*, QDeadlineTimer) + 87
4 QtQuick 0x11135f704 0x111061000 + 3139332
5 QtQuick 0x111366256 0x111061000 + 3166806
6 QtQuick 0x1113667bc 0x111061000 + 3168188
7 QtCore 0x1130c6425 0x112e77000 + 2421797
Thread 14:: CVDisplayLink
1 libsystem_pthread.dylib 0x7ff8060f2229 _pthread_cond_wait + 1044
2 CoreVideo 0x7ff810b8a911 CVDisplayLink::waitUntil(unsigned long long) + 375
3 CoreVideo 0x7ff810b89854 CVDisplayLink::runIOThread() + 524
Thread 15:
Thread 16:: Thread (pooled)
2 QtCore 0x1130cf59a 0x112e77000 + 2459034
4 QtCore 0x11301a18b 0x112e77000 + 1716619
Thread 17:: Thread (pooled)
Thread 18:: Thread (pooled)
Thread 19:: Thread (pooled)
Thread 20:: Thread (pooled)
Thread 21:: Thread (pooled)
Thread 22:
2 libc++.1.dylib 0x7ff80600f948 std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 audacity 0x10d896e77 DBConnection::CheckpointThread(sqlite3*, wxString const&) + 199
4 audacity 0x10d89853a 0x10c6c8000 + 18679098
Thread 23:: QSGRenderThread
Thread 24:
Thread 25:: HIE: M_ f7a17b5ddd92a6c2 2026-09-20 18:17:54.386
2 libsystem_kernel.dylib 0x7ff8060d520f thread_suspend + 83
3 HIServices 0x7ff80d49f971 SOME_OTHER_THREAD_SWALLOWED_AT_LEAST_ONE_EXCEPTION + 16
4 Foundation 0x7ff807415bc3 NSThread__start + 1014
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000000ffffffff rbx: 0x00007fe66702d5e0 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x00007fe670cad6b0 rsi: 0x00007ff825d488ff rbp: 0x00007ff7b3830b40 rsp: 0x00007ff7b3830ac8
r8: 0x0000000000000007 r9: 0xfffffffffffff000 r10: 0x0000000000000000 r11: 0x00007ff825d488ff
r12: 0x00007fe6701f75e0 r13: 0x0000000000000000 r14: 0x00007fe670c6d1e0 r15: 0x00007fe6701f6060
rip: 0x00007ff805c8b09d rfl: 0x0000000000010246 cr2: 0x0000000000000018
Logical CPU: 4
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
