I’m using Audacity 2.3.0 and was working on a fairly large .aup file. Decided to take a break and when I went to open it again, an Error Importing message showed up. The message reads exactly:
“LOCATION OF FILE” is an Audacity Project file. Use the ‘File > Open’ command to open Audacity Projects.
I opened the file exactly how it said to open it, and yet it still interprets it as me trying to import an .aup file. This only happens on this specific file. I tried every other .aup file in that folder and they all worked perfectly. I checked the data folder for it and all the samples of audio are there in mono form. Is there any easy way to recover this file?
