Audacity Debug Report Help?
I keep getting this debug report whenever I click on Audacity to record, and for some reason now I cannot even use Audacity because of this debug report. Can anybody help me with this?
Please provide the information requested in the pink panel near the top of this page.
What are you trying to record from?
Try rebooting, then shut down any audio applications that open automatically (including Skype, Spotify, and any others), then try Audacity again. Do you still get the problem?
I am trying to record from Blue Yeti Microphone, it worked a couple of days ago but all of a sudden today, Audacity would not open at all. I uninstalled it, reinstalled it and this would keep popping up
I tried uninstalling it and reinstalling it but this message keeps coming up. I was trying to record from Blue Yeti by the way. I just wanna use Audacity to record commentaries…but this keeps popping up no matter what I do. And when I do uninstall it, I get this message that says some components could not be removed
Reinstalling Audacity will make no difference unless you also select the option to “Reset Preferences” during the installation process.
Press OK on the Debug Report window to quit Audacity before uninstalling.
When you reinstall, use the current Audacity 2.1.2 from http://audacityteam.org/download/windows.
Have you always had this problem with Audacity recording from Yeti?
