This problem was discovered after Audacity 2.3.2 was released.
The workaround is to set a preset in the Equaliztion effect manually, before opening the Macro manager.
This has been fixed in the next version of Audacity by replacing the effect with a new effect. Unfortunately the downside is that any macros that you make now, you will need to update for Audacity 2.3.3.
