Hello,
I am using macOS High Sierra version 10.13.6 and audacity2.4.2
I am doing a podcast and Audacity keeps crashing and the app closes after i try to edit something.
I have read other similar question/answers on the forum and tried the solutions given but it hasn’t worked.
Any suggestions?
Thank you!
Could you post a screen shot of your project before the crash?
Are any of your tracks at a sample rate of 32000?
– Bill
Yes i think they all are at a sample rate of 32000. what should i change them to?
Set the “Project Rate” (lower left corner of the main Audacity interface) to 44100.
Then “Select menu > All”.
Then “Tracks menu > Resample” and resample to 44100.
i did exactly that and it works again!
thank you so much
