I have an external blue yeti mic (connects thru USB) and whenever I try to record with it, Audacity crashes after a second (you see the recording bar trying to move, freezes, and then everything crashes) . I switched to the built-in mic on my laptop and everything is fine. Does anyone know how to fix this?
Same reason I use Mavericks instead of Yosemite. I have the entirely unfashionable idea that the software should do what I want instead of compulsively updating to the latest version and taking my chances. I have a little thrill watching people update to beta (or even alpha) software and then complaining about bad behavior.
āThank you for being a Beta Tester.ā
Clients tend to not care about being a beta tester.
I do use Audacity 2.1.2 for support, so Iām seeing the same panels and displays as everybody else.
Itās looking good I will shortly be joining the Yosemite gaggle. Iām generating work that requires a lighter and more portable machine. I checked behind the sofa seat cushions and there was more back there than I thought. Between that and the change cup from Lori (my lorry) I may be able to spring for extra memory.
On the other hand, the newest version of Audacity has fixed a bunch of problems that Iād been having: crash after a long recording session (no data lost, but some time) or after a period of inactivity when the mac had gone to sleep; and alert windows on reopening, and logs created (which I could never find) etc etc etc.
But after upgrading to the newest version, none of that!! And it wasnāt until just today that I noticed that the effects tool bar allows me to import plug-ins instead of using the finder to move them into the new plug-ins folder.
Bravo! Loving it!
I think most of that improvement was due to upgrading to a newer version of wxWidgets. We knew about those crashes but most of us have Mac Minis and could not reproduce them.
However on my Mac Mini (only 4 GB RAM and ~2 GHz) Audacity dialogues like How to get Help and open/save dialogues are slower to open in 2.1.2 than in 2.1.1, and show black content while loading. Also I donāt see the Audacity open/save dialogues starting small and getting larger that some people are complaining about (I think itās a Mac āeffectā that the new version of wxWidgets now supports).
Hi Koz
Iām using 10.11.1 OSX
My yeti plugs in to my laptop via the USB port
I tried with the headphones, and tried to play music on my laptop. The sound just comes out of the external speakers on my laptop, but I do hear a quiet static-y sound from the earphones when I plug them into the yeti.
Hi Gale
Iāve opened up the console app but how do I post the crash report⦠and how do I know which one is the crash report? and how do I post it? Should I take a screenshot?
In Console.app, look in the tree on the left. Scroll down and look under FILES for /Library/Logs (not ~/Library/Logs, though sometimes hang reports may be there).
Double-click that /Library/Logs line to expand it. In the expanded list under /Library/Logs, find āDiagnostic Reportsā and double-click to expand that line. You should now see the Audacity crash reports listed in the tree, latest crash last.
You can now right-click the line in the tree for that report and choose āReveal in Finderā, or (with the line for that report still selected) use File > āSave a Copy Asā in Consoleās File menu.
