I am running Audacity 2.0.5 (downloaded from repositories) on Linux Mint 17.2 (Linux version 3.16.0-38-generic (buildd@aatxe) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #52~14.04.1-Ubuntu)
I have just tried to import Raw Data and look at its spectrum but Audacity crashed with a segmentation fault. No error messages are generated by Audacity.
How to reproduce:
- Launch Audacity;
- File → Import → Raw Data…;
- Choose the attached file “BUG CAUSING VERY DANGEROUS NEVER LOOK AT THE SPECTRUM BLYAD”;
- Choose the following options:
- Encoding: 64 bit float;
- Byte order: Big-endian;
- Channels: 1 Channel;
- Start offset: 0 bytes;
- Amount to import: 100 %;
- Sample rate: 44100 Hz;
- Try to look at the spectrogram.
- Segmentation fault!
You can see the output in the attached files.
audacity_err and audacity_out.zip (1.07 KB)
BUG CAUSING VERY DANGEROUS NEVER LOOK AT THE SPECTRUM BLYAD.zip (168 KB)
