I tried tu use Amplio2 plugin and Audacity crashed.
Operating System: windows 10.
Audacity_dbgrpt-7436-20151105T111708.zip (148 KB)
It is 4 NOV alpha. Sory for mistake.
Thanks for the report. I found it prone to crash even when trying to enable it. It seems safe if you open it without audio playing and then press Apply, without pressing Play in the effect. I added a bug report http://bugzilla.audacityteam.org/show_bug.cgi?id=1257.
