Hi! I have an Audacity 1.3.13 old version and when I edit the audio file, I get this error popup to “Error writing autosave file”, unfortunately I didn’t find much in this forum, so I ask you: is there an option in this version how to manually change AutoSave directory (C:\Users\nameuser\AppData\Roaming\Audacity\AutoSave) to another directories? And how do I disable popup messages in Audacity (since there isn’t even a setting on that)? And how do disable the AutoSave? I await your reply, thank you!
Audacity 1.3.13 is ancient (April 2011) and no longer supported.
Unfortunately that’s what I’m with compared to the later versions, but I’m surprised that it doesn’t have settings I would like…
