When I first hooked up my Shure MV7 Headphones, they worked with Audacity and I was able to edit tape using my headphones. Then they stopped working. The headphones work with everything else EXCEPT Audacity. I uninstalled Audacity and reinstalled but still don’t work. I believe I have all the correct settings. Can someone help?
Two things to check:
- Does Audacity work with your built-in microphone ? If not, you will need to setup microphone permissions for Audacity on your computer. On Windows this would be: Turn on app permissions for your microphone in Windows 10 - Microsoft Support.
- After plugging in this USB microphone, you will need to either a) restart Audacity or b) run Transport > ReScan Audio Devices.
