Audacity cannot find project data folder
I’m having the same problem. The .aup file and the folder are together. Is there a way I can show audacity where the folder is?
Here Is One Example because I moved my folders and moved them back, so if moving the .aup file helps its fine, but fixing it in edit pad or note pad works, that’s fine too.
<?xml version="1.0" standalone="no" ?>
<!DOCTYPE project PUBLIC "-//audacityproject-1.3.0//DTD//EN" "http://audacityteam.org/xml/audacityproject-1.3.0.dtd" >
<project xmlns="http://audacityteam.org/xml/" projname="Chance in the Air_data" version="1.3.0" audacityversion="2.0.5" sel0="0.0000000000" sel1="0.0000000000" vpos="0" h="0.0000000000" zoom="8.8820234682" rate="44100.0">
	<tags>
		<tag name="major_brand" value="mp42"/>
		<tag name="Encoding time" value="2008-11-19 14:37:39"/>
		<tag name="Software" value="Lavf53.32.100"/>
		<tag name="compatible_brands" value="isomavc1mp42"/>
		<tag name="minor_version" value="0"/>
	</tags>
	<wavetrack name="Genius GZA - Living In The World Today (Instrumental)" channel="0" linked="1" mute="0" solo="0" height="150" minimized="0" isSelected="1" rate="44100" gain="1.0" pan="0.0">
		<waveclip offset="0.00000000">
			<sequence maxsamples="262144" sampleformat="262159" numsamples="13475240">
				<waveblock start="0">
					<simpleblockfile filename="e000015f.au" len="262144" min="-0.73998" max="0.775953" rms="0.100027"/>
				</waveblock>
				<waveblock start="262144">
					<simpleblockfile filename="e0000301.au" len="262144" min="-0.367274" max="0.435356" rms="0.075845"/>
				</waveblock>
				<waveblock start="524288">
					<simpleblockfile filename="e0000711.au" len="262144" min="-0.338803" max="0.391658" rms="0.079208"/>
				</waveblock>
				<waveblock start="786432">
					<simpleblockfile filename="e0000eeb.au" len="262144" min="-0.64684" max="0.70646" rms="0.148092"/>
				</waveblock>
				<waveblock start="1048576">
					<simpleblockfile filename="e0000677.au" len="262144" min="-0.814586" max="1.010231" rms="0.197602"/>
				</waveblock>
				<waveblock start="1310720">
					<simpleblockfile filename="e0000b56.au" len="262144" min="-1.09586" max="1.107986" rms="0.208098"/>
				</waveblock>
				<waveblock start="1572864">
					<simpleblockfile filename="e0000028.au" len="262144" min="-0.999989" max="1.127829" rms="0.196815"/>
				</waveblock>
				<waveblock start="1835008">
					<simpleblockfile filename="e0000afb.au" len="262144" min="-1.07079" max="1.170483" rms="0.191661"/>
				</waveblock>
				<waveblock start="2097152">
					<simpleblockfile filename="e0000b82.au" len="262144" min="-0.903826" max="1.004236" rms="0.185254"/>
				</waveblock>
				<waveblock start="2359296">
					<simpleblockfile filename="e0000a95.au" len="262144" min="-0.998914" max="1.046226" rms="0.190477"/>
				</waveblock>
				<waveblock start="2621440">
					<simpleblockfile filename="e0000e58.au" len="262144" min="-0.989967" max="0.979527" rms="0.196833"/>
				</waveblock>
				<waveblock start="2883584">
					<simpleblockfile filename="e0000f34.au" len="262144" min="-1.134991" max="1.126862" rms="0.199884"/>
				</waveblock>
				<waveblock start="3145728">
					<simpleblockfile filename="e00002d4.au" len="262144" min="-1.028094" max="1.073494" rms="0.186342"/>
				</waveblock>
				<waveblock start="3407872">
					<simpleblockfile filename="e0000d6b.au" len="262144" min="-1.155337" max="1.064902" rms="0.19384"/>
				</waveblock>
				<waveblock start="3670016">
					<simpleblockfile filename="e0000d1a.au" len="262144" min="-0.972078" max="1.115456" rms="0.201013"/>
				</waveblock>
				<waveblock start="3932160">
					<simpleblockfile filename="e000082e.au" len="262144" min="-1.000834" max="1.115217" rms="0.199754"/>
				</waveblock>
				<waveblock start="4194304">
					<simpleblockfile filename="e0000675.au" len="262144" min="-0.998612" max="0.98813" rms="0.201521"/>
				</waveblock>
				<waveblock start="4456448">
					<simpleblockfile filename="e00006d9.au" len="262144" min="-0.921448" max="1.061983" rms="0.195969"/>
				</waveblock>
				<waveblock start="4718592">
					<simpleblockfile filename="e00009e0.au" len="262144" min="-1.034948" max="1.041236" rms="0.183667"/>
				</waveblock>
				<waveblock start="4980736">
					<simpleblockfile filename="e0000c97.au" len="262144" min="-0.992584" max="1.116164" rms="0.188313"/>
				</waveblock>
				<waveblock start="5242880">
					<simpleblockfile filename="e0000fd8.au" len="262144" min="-0.954662" max="1.072086" rms="0.147654"/>
				</waveblock>
				<waveblock start="5505024">
					<simpleblockfile filename="e0000f7a.au" len="262144" min="-0.923021" max="1.011166" rms="0.128906"/>
				</waveblock>
				<waveblock start="5767168">
					<simpleblockfile filename="e00009a6.au" len="262144" min="-1.232287" max="1.119187" rms="0.19307"/>
				</waveblock>
				<waveblock start="6029312">
					<simpleblockfile filename="e0000834.au" len="262144" min="-1.072512" max="1.173748" rms="0.198308"/>
				</waveblock>
				<waveblock start="6291456">
					<simpleblockfile filename="e0000482.au" len="262144" min="-1.068069" max="1.041598" rms="0.187957"/>
				</waveblock>
				<waveblock start="6553600">
					<simpleblockfile filename="e0000224.au" len="262144" min="-1.068809" max="1.04479" rms="0.196427"/>
				</waveblock>
				<waveblock start="6815744">
					<simpleblockfile filename="e0000a34.au" len="262144" min="-0.941699" max="1.022107" rms="0.172247"/>
				</waveblock>
				<waveblock start="7077888">
					<simpleblockfile filename="e0000d4a.au" len="262144" min="-0.993661" max="0.979094" rms="0.186109"/>
				</waveblock>
				<waveblock start="7340032">
					<simpleblockfile filename="e0000fc4.au" len="262144" min="-1.241452" max="1.215221" rms="0.199549"/>
				</waveblock>
				<waveblock start="7602176">
					<simpleblockfile filename="e0000477.au" len="262144" min="-1.100471" max="1.022108" rms="0.194338"/>
				</waveblock>
				<waveblock start="7864320">
					<simpleblockfile filename="e0000bf6.au" len="262144" min="-0.867526" max="0.989295" rms="0.150642"/>
				</waveblock>
				<waveblock start="8126464">
					<simpleblockfile filename="e0000ebc.au" len="262144" min="-0.90017" max="1.120686" rms="0.188635"/>
				</waveblock>
				<waveblock start="8388608">
					<simpleblockfile filename="e0000492.au" len="262144" min="-0.966036" max="1.052163" rms="0.195722"/>
				</waveblock>
				<waveblock start="8650752">
					<simpleblockfile filename="e00002ca.au" len="262144" min="-0.970865" max="1.093363" rms="0.198478"/>
				</waveblock>
				<waveblock start="8912896">
					<simpleblockfile filename="e000024f.au" len="262144" min="-1.039718" max="1.078857" rms="0.198039"/>
				</waveblock>
				<waveblock start="9175040">
					<simpleblockfile filename="e000011e.au" len="262144" min="-1.078503" max="1.075022" rms="0.205761"/>
				</waveblock>
				<waveblock start="9437184">
					<simpleblockfile filename="e00000ea.au" len="262144" min="-0.916583" max="1.067963" rms="0.211979"/>
				</waveblock>
				<waveblock start="9699328">
					<simpleblockfile filename="e00007f3.au" len="262144" min="-0.991899" max="0.978391" rms="0.191882"/>
				</waveblock>
				<waveblock start="9961472">
					<simpleblockfile filename="e000064c.au" len="262144" min="-1.019787" max="0.999734" rms="0.187415"/>
				</waveblock>
				<waveblock start="10223616">
					<simpleblockfile filename="e00004ae.au" len="262144" min="-0.992015" max="1.145571" rms="0.19707"/>
				</waveblock>
				<waveblock start="10485760">
I started a new topic for you. It gets too confusing to answer multiple people’s subtly different issues in the same topic.
You should never rename AUP files and _data folders by hand, or move a project’s _data folder to another folder than the AUP file is in.
A project called “song.AUP” needs to be in the same folder as its _data folder called “song_data”. It is as simple as that.
If you want to rename a project, use File > Save Project As… . Reading this page thoroughly may help: http://manual.audacityteam.org/o/man/audacity_projects.html.
If that is the complete AUP file, it would not open because it is truncated.
If that AUP files is complete, find the folder called “Chance in the Air_data” and put it in the same folder that “Chance in the Air.AUP” is in.
If you have renamed “Chance in the Air_data” to some other name, find the renamed folder and change its name back to “Chance in the Air_data”.
