_00
July 19, 2024, 5:59pm
1
Hello! Audacity 3.6.0 became to do automatically “select all” after I open file (associated with Audacity), after importing, I have to remove selection. Please, correct.
Came looking for this. Noticed the same. Thanks.
Good catch, thanks for the report @_00
I have logged this as a regression bug on Muse’s GitHub issues log:
opened 10:36AM - 20 Jul 24 UTC
bug
regression
import-export
### Bug description
In 3.6.0 and 3.6.1 test builds - when you import an audio f… ile audacity now selects that imported audio - and of course in so doing this replaces and thus destroys any selection that the user may have carefully made.
This is a regression on 3.5.1 and all earlier Audacity versions.
Reported by two users on the Forum:
https://forum.audacityteam.org/t/audacity-automatically-does-select-all-after-importing-file/112215
https://forum.audacityteam.org/t/audacity-3-6-is-out-now/111894/42
### Steps to reproduce
1. Import an audio file
2. Observe: the track is auto-selected
3. make a small selection on the track
4. Import a second audio track
5. Observe: this ne track is selected, thus removing the selection made at step 3
### Expected behavior
Imported audio should **_not_** be auto-selected
### Actual behavior
Imported audio is auto-selected - removing any prior extant selection
### Audacity Version
latest stable version (from audacityteam.org/download)
### Operating system
### Additional context
_No response_
Peter
Use File > Import - or use drag&drop
See this page in the Audacity manual:
https://manual.audacityteam.org/man/importing_audio.html
Peter
_00
July 20, 2024, 12:34pm
6
You also can associate (open with…) audio file (.mp3 or else) with audacity.
@lightstorm22 @_00 What’s your use case for the old behavior? Where exactly does the new behavior get in the way of your workflow?
_00
July 22, 2024, 11:05am
8
At first I associated .mp3-files with Audacity. So that after clicking “open” in context menu it is opened by Audacity, as if it’s imported. I did so to make import easier. And then it happens, as we wrote. The entire track is already selected, though I didn’t touch any button yet. There was no such problem in all previous versions.
system
Closed
August 18, 2024, 5:59pm
11
