I agree with you here Steve. If I do any mp3 conversion, it’s always at 256 or greater.
WAV is a lossless format. Any difference in sound between playing a WAV file in Audacity or any other audio player will most likely be just that you have the volume level set differently.
What I started to do some time ago is to first take the bass and drum tracks I’ve recorded in Audacity, mix it down and export it to wav format. I then import it back into Audacity, normalize the volume, and copy my labels over. Having the backing tracks labeled is invaluable, especially during a performance.
If you use WAV format and set the volume level appropriately there is no reason why you cannot achieve exactly the same sound quality in other players as you do with Audacity. Many other players have the advantage of playlist support (Audacity does not support playlists). I was not able to look up details of how the pok controller works as I’m not a registered user, but I assume that you can configure each button to send a key press or key press combination. If that is correct then probably the best solution would be to use an audio player that supports playlists, then configure the controller so that you can step through the playlist. There are many alternative players that support playlists, including Rhythmbox, VLC, Clementine, Amarok, and many more.
I’ve tried the all the audio players you’ve mentioned and have gone down the “playlist road”. There’s no problem controlling them with The Pok but I found this scenario to be limiting when performing. Most importantly, I lose label support.
That being said, and in reference to my original post, I found an easy and fairly quick way to set up what I need. XFCE (which I use the most) seems to be the only DE that will allow me to this. Here’s what I did this morning:
Initial Setup:
- I went into the Workplace Settings ( in the XFCE Settings Manager) and set the number of workspaces to 23. I kept Workspace 1 as my main, then added and renamed 22 others… Each workspace now has the name of an individual tune, and in the order of my set list.
- I then added the Workspace Switcher plugin to the panel to have a graphical representation.
- I set the number of rows in the Workspace Switcher to 4, and enabled " Show miniature view".
- Back in the Settings Manager, I opened the Keyboard tab in the Window Manager and set the “Next workspace” action to ALT-1 (which is already programmed into my pedal).
All of the above is a one time deal since it’s saved in my session settings.
Audacity Setup:
- I open Audacity in Workspace 1 and all 22 tunes (22 Audacity windows open). On this note, I find Linux to be way faster than Windows, and XFCE faster than Cinnamon (3D and 2D), or Gnome 3. Haven’t tried it in Mate.
- I then move each open tune (Audacity window) to the workspace with the same name. This is easily and quickly done by right clicking the open tab in the panel and following the menu/drop-down box. It’s this functionality that seems to be unique to XFCE.
I can now cycle though the tunes using my mouse wheel, mouse pointer on the panel, keyboard, and most importantly… my pedal.
On a different subject, your pedal looks like it would probably work well with > SuperLooper> .
It actually works well with anything. I used to use loopstations and have owned and/or tried pretty much all of them… both hardware and software. They’re great at what they do but I found over time that my musical needs required a computer based solution. When I migrated to a computer using Audacity, the issue was controlling it, especially with two hands on a guitar
The Pok solved that problem.
BTW, the Pok connects to my laptop via a USB dongle which sends an RF signal. The software to program the shortcuts and the pedal’s functionality is Windows and Mac based. However, once programmed, you can use it in Linux as long as the shortcuts match in whatever program is being used.
