# Audacity and Roland D5
**URL:** <https://forum.audacityteam.org/t/audacity-and-roland-d5/42775>\
**Category:** macOS\
**Created:** [June 29, 2016, 2:35am UTC](https://forum.audacityteam.org/t/audacity-and-roland-d5/42775 "2016-06-29T02:35:33Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Vlad](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/v/3bc359/32.png) [@Vlad](https://forum.audacityteam.org/u/Vlad)\
**Post date:** [June 29, 2016, 2:35am UTC](https://forum.audacityteam.org/t/audacity-and-roland-d5/42775/1 "2016-06-29T02:35:33Z")
</div>
Hello,
I just downloaded Audacity 2.1.2. to my MacBookPro with Yosemite OS.
Then I imported a short mp3 file with a preexisting musical recording.
I’m trying to add an additional track from Roland D5 linear synthesizer.
I’m not outputting MIDI data sequence but a simple audio signal.
For this I purchased T-Connect USB cable (headphone jack to USB). I’m using Line Output from my keyboard.
Although I see it registered as C-Media USB Headphone Set (?) in my Mac System Preferences window, the Audacity software doesn’t allow me to change the input from its pre-set Mic option. Therefore I can record my voice for example but not the much needed piano melody.
What am I doing wrong?
I’d greatly appreciate your help.
Thanks,
Vlad
**Author:** ![kozikowski](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/k/919ad9/32.png) [@kozikowski](https://forum.audacityteam.org/u/kozikowski)\
**Post date:** [June 29, 2016, 3:06am UTC](https://forum.audacityteam.org/t/audacity-and-roland-d5/42775/2 "2016-06-29T03:06:41Z")
</div>
Just going from the words, you have an adapter that provides a stereo headphone connection and a mono microphone connection suitable for a computer headset or stand-alone computer microphone.
I use an ICUSBAUDIO from Startech to do the same thing.
Neither of these has a place to connect a high-volume stereo audio cable for recording.
I use a Behringer UCA-202 to record my stereo sound mixer. It’s a bi-directionial stereo USB interface of good quality and low cost. It’s certified for Audacity overdubbing/sound-on-sound because of its zero latency headphone connection.
![](http://www.kozco.com/tech/audacity/pix/peaveyUCA202Lenovo-650.jpg)
We reviewed other similar interface devices.
[https://forum.audacityteam.org/t/sound-card-reviews/8375/1](https://forum.audacityteam.org/t/sound-card-reviews/8375/1)
**Post date:** [June 29, 2016, 5:25pm UTC](https://forum.audacityteam.org/t/audacity-and-roland-d5/42775/3 "2016-06-29T17:25:44Z")
</div>
Thank you for your speedy reply!
Are you saying that T-Connect is not the right choice?
Is my output too low or too high? (I’m not an audio specialist).
I checked Amazon and some folks have issues with Behringer’s quality.
Vlad
**Post date:** [June 30, 2016, 12:04am UTC](https://forum.audacityteam.org/t/audacity-and-roland-d5/42775/4 "2016-06-30T00:04:22Z")
</div>
That’s because it doesn’t have anything but the microphone input. These interfaces are used with a computer microphone.
![](https://forum.audacityteam.org/uploads/default/original/3X/a/0/a05fc3a18fbc8761f8b00411ae698579625a0e18.jpeg)
Or a headset (I guess they’re calling it a **Headphone Set** ) A **Headset** is a matched set of microphone and headphone.
 ![](https://forum.audacityteam.org/uploads/default/original/3X/5/b/5b4dcf74655eb886167f0ff9fdbfcf1df0bff02e.jpeg)
Those were taken when that process was done with two different plugs. It can all be done with one now.
In both cases the microphone signal is mono (one blue wave) and really, _really_ tiny. Unless it says so, two signals (stereo) at high volume (Mixer output) is going to be damaged through missing parts and high volume distortion. It’s just the wrong adapter.
Our experience has been of Behringer supplying very high quality equipment through personal use, multiple users and purchases. What’s the address of the comments critical of Behringer?
The forum did collect and published comments on other interfaces.
> [@Sound Card Reviews](https://forum.audacityteam.org/t/sound-card-reviews/8375/1):
> This topic concerns mono/stereo sound cards and recording devices. Multi-channel recording devices are listed here: [http://forum.audacityteam.org/viewtopic.php?f=27&t=38626](http://forum.audacityteam.org/viewtopic.php?f=27&t=38626) How well does your sound card work with Audacity? Audacity will work with the vast majority of sound cards, however some sound cards are known to have issues, while others are known to work flawlessly. Given that many Audacity users will at some point want to replace/upgrade their sound card, and the huge range of products …
Whatever you decide on, make sure it says in clear English that it supports Stereo Line signals for recording. Don’t fall for the “Mic-Line” phrase. That’s a nonsense term the makers use to try to fool you into buying their product—unless the documentation says the unit can switch. Such adapters do exist.
**Author:** ![Gale\_Andrews](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/g/e0b2c6/32.png) [@Gale\_Andrews](https://forum.audacityteam.org/u/Gale_Andrews)\
**Post date:** [June 30, 2016, 5:31pm UTC](https://forum.audacityteam.org/t/audacity-and-roland-d5/42775/5 "2016-06-30T17:31:49Z")
</div>
> [@Vlad](#):
Whatever USB audio device you use, it must be connected before you launch Audacity.
If you connect the device after Audacity is open, use Transport \> Rescan Audio Devices from the top of the Audacity menus.
