Audacity and Audio Hijack Pro
Hi.
I use Audio Hijack Pro to make recordings.
It has an ‘editor’ button that automatically opens a recording in your editor of choice, mine being Audacity. Since installing 2.0.4 the connection between that button and Audacity doesn’t work. I have restarted etc but no luck. Any ideas?
Regards,
Max.
“Doesn’t work” in what way? Does Audacity crash, or simply not launch?
The preference may look for a specific version number of Audacity, or may lose the connection if you trashed a previous version when you installed 2.0.4. Have you gone to the Audio Hijack prefs and set the connection again?
– Bill
No, nothing crashes. In fact, when the button is pushed it does switch to Audacity up in the menu bar. But there’s no Audacity page open. I need to take the file from the desktop and drag it in after opening an Audacity page.
I have re-set the preferences but it hasn’t corrected the problem.
OK, I can confirm this. Works OK with 2.0.3, does not work with 2.0.4, although I get a blank Audacity project window but no file imported.
I’ll raise this with the developers.
– Bill
Thanks a lot Bill.
