Audacity/Acer aspire 3, win 11/behringer Q1204 problem
Hi, using a Behringer Q1204usb Mixer to a new Acer Aspire 3 Laptop running windows 11, Zara Radio & audacity 3.4.2. Audacity is not connecting to this at all. However, it was fine on my W10 / Acer PC.
HELP!! thx
Does it show-up in Audacity as a Recording Device?
Check your Privacy Settings..
And if you have another USB cable, try it.
I’m pretty sure it’s supposed to be Class Compliant so it should be plug-and-play with the standard Microsoft-supplied drivers.
Hi Doug,
I have checked settings in laptop, changed USB cable
But still not working…
Would it be anything to do with the 2 to 1 connector to the laptop jack socket as it is in/out, not just headphones?
Thanks
