Audacity 4.0 is unusable for serious audio editing – multiple critical usability problems
I am extremely disappointed with Audacity 4.0 and have decided to stop using this version because its numerous problems make even basic audio editing unnecessarily difficult.
During normal use on Windows 11, I encountered the following issues:
  1. Misaligned mouse cursor: Clicking on the waveform places the editing cursor noticeably to the right of the actual mouse position. The problem occurs after launching Audacity and eventually disappears, but makes precise editing unreliable.
  2. Severe horizontal scrolling lag: Moving through the audio using the horizontal scrollbar can be extremely slow, with noticeable delays.
  3. Inconsistent mouse-wheel behavior: Shift + mouse wheel sometimes scrolls horizontally while simultaneously changing the zoom level with every wheel movement. Later, the same operation starts working normally without any clear explanation.
  4. Unreliable loop playback: After carefully defining a loop region, I could not get Audacity to play the intended section. Playback repeatedly started at a completely different position. The loop-region marking eventually disappeared.
  5. Disruptive timeline navigation: Unexpected zoom changes make it difficult to navigate through the audio and return to the exact section being edited.
These are not minor cosmetic issues. They interfere directly with the most fundamental tasks of an audio editor: navigating, selecting, playing and precisely editing audio.
I have spent far more time troubleshooting Audacity than actually editing audio.
I refuse to continue using Audacity 4.0 in its current state. I need a reliable audio editor, not software that constantly interrupts my work with unpredictable behavior.
Please investigate these problems and prioritize stability, predictable controls and precise editing over interface changes.
I would also appreciate clarification on whether these issues are already known and which fixes are planned.
Welcome to the club of folks that find Audacity 4 to be an incomplete, buggy, unusable POS.
The only thing I can tell you is create a github account and report the bugs here Issues · audacity/audacity · GitHub
Whether anything will actually be done to fix your issues, who knows.
