Audacity 3.7.4 hangs during load
Similar to this post:
and:
Windows 11 Pro
I also have RODE Go II system and their podcasting software, which installs some custom RODE audio devices.
Curiously, I did as the last post, un-installed (I usually install on top of). Got a notice some items could not be removed. Manually went and deleted the program folder.
Re-installed, clicked the box to RESET settings.
And it worked once! heheh.
Posting this as a “fix” but if it does it again, I’ll be back!
Argh! The very next time I tried to open Audacity it hangs with the splash screen - again. The splash is modal so it wont go away and you cant move it. Have to force quit Audacity to get out.
I am using RODE Go II mics - two RX and 4 Tx. To record them I installed Rode’s “Rode Connect” Podcastor recording software V 1.3.43. As well as “Rode Central” to manage the hardware and on-board recordings.
I notice something - the Podcaster? - has added custome ROD devices to Windows Audio sources and speakers.
My suspicion is Audacity is hanging trying to get details or connect with the virtual devices.
Is there a way to avoid that? Or verify this is indeed why its hanging on the Splash screen?
Update: After I force quit Audacity I opened Windows Sound settings and discovered it said I had “No Audio devices”! I ran the troubleshooter that brought back all my devices, including the Rode virtual ones. But no sound. The troubleshooter was still open, I clicked “No” this did not fix it. It said it RESET my audio drivers but I needed to reboot.
After a reboot, audio worked. And Audacity opened right up without much delay!
I pulled a diagnostic report hoping it might shed some light. The system will let me attach the 10K ZIP file!!!
I tried to attach the contents, 5 at a time. Only to be then told new users can only have two “links”. Not impressed. I’ll pick two files, if you want any of the others just ask.
Thanks in Advance!
audacity.cfg (7.8 KB)
audiodev.txt (12.2 KB)
