MacOS 10.13.6, Audacity 3.3.0
Can’t go any further. Is there a way to bypass the verifying step?
If you download the version specific to your architecture (eg the …x86_64.dmg) instead of the universal binary, it likely will work.
OK, I’ll try that. HOWEVER, the System Requirements indicate that both the Universal and the …x86_64 versions will run on Intel Macs starting with MacOS 10.13.x (High Sierra). Perhaps a clarification should be made?
Edit. The non-Universal worked. Thanks.
As far as I can tell the universal build generally works, even on 10.13. But in cases where it gets stuck verifying, using the non-universal version tends to work around whatever makes it stuck.
