Hallo and hello, to the Audacity team,
I use Audacity with a Steinberg U12 with Ubuntu 18.04 Linux, this combination works great without problems, I use that to do voice analysis.
(Analysis → draw spectra)
For that it would be very helpful if the window in the spectra can be calculated and displayed larger in order to have a better resolution between 100Hz to 3000Hz.
(Edit → Settings) Spectra
In this window you can set (example 100Hz-3000Hz) but it does not work.
Unfortunately, my programming skills are too bad to do it myself, it would be great if I could soon have a solution to this need.
Yours sincerely.
Franz Bertels
