audacity 2.1
Is there an “auto save” option that saves the entire recording when I “stop” the recording or close the app? This will be easier than manually having to save an entire recording. In the video capture app DEBUT that is how that app works. When recording is stopped the recording(s) are moved to a built in SAVE box. The recordings are brought up by choosing that tab, and then selecting a recording to play from that screen. I do not mind looking for the stored recordings folder bur it would be nice if the app auto saved at stop or closing.
Save the empty project before you start work - that way the Temp files will not be used and subsequent Saves will be quicker.
