Audacity 2.1.2 Doesn't Remember Settings on 2nd Monitor
When using Audacity 2.1.2 on a two (2) monitor system, the software does not “remember” window size, position, or monitor to launch on.
Steps to reproduce: (1) Launch Audacity; (2) Move the application to your SECOND monitor; (3) size and position the application; (4) Exit Audacity; (5) Re-Launch Audacity. It will launch on the PRIMARY monitor, and the window size and location is NOT restored (it actually “resets” it to the default size/position on the PRIMARY monitor).
Window size and position ARE retained when Audacity is launched and run from the PRIMARY monitor.
Thanks for the feedback.
This is a known issue in Audacity 2.1.2. There is a fix for it in the current development code so all being well it will be fixed in the next (2.1.3) release.
