Audacity 2.1.1 VST plugins do not enable
So I’m having a problem with effects. I’ve downloaded the VST bridge for Audacity but when I try to enable anything it says that it’s enable and then doesn’t. I click okay and then when I open the manager again it’s just written down as new.
VST-bridge is not needed for 2.1.1 to enable VST effects. Please delete VST-bridge.
Which exact VST plugin is causing the problem, with link to its web site? Note that Audacity does not support 64-bit VST plugins, VST 3 or VST instruments.
Deleted. Hmm, it was a instrument that must be the problem. Thank you.
