I was able to download the 2.0 SVN code and compile on Ubuntu 10.04 (Lucid) (x86-64)
after installing all of the wxwidgets 2.8.12 code.
Couple of minor problems:
Since my (and AFAIK every) Ubuntu distro uses PulseAudio, I get a bunch of
ALSA errors when launching Audacity 2.0. I dont’ know if I have a bunged up
Alsa config, but these line seems to be the key:
Expression ‘stream->capture.pcm’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 3857
Audacity 2.0 actually can capture an input stream fine when newly lanuched, but sometimes I have to relaunch it
when it messes up.
It can’t seem to find my FFMPEG libs, even though I downloaded source, compiled and installed them.
(Of course I’ve tried setting the lib manually) Doesn’t seem to matter much, though. Should it?
The menus tend to disappear sometimes. I can usually do something and get wxwidgets to refresh them.
Looking forward to trying the improved noise reduction, among other goodies.
FFmpeg can be a pain because of dependencies.
I believe that FFmpeg is included in the Audacity dependencies, and the standard Ubuntu distro version of FFmpeg should work fine with Audacity 2.0.
The easiest way to satisfy all of the dependencies in Debian based distributions is to use:
sudo apt-get build-dep audacity
If you ran “sudo make install” to install Audacity, run “sudo make uninstall” to uninstall it.
Ubuntu installs the repo version of Audacity into /usr/ but the default configuration for the source code is /usr/local/
If you configure Audacity to install in /usr/ then Audacity should automatically find any LADSPA plug-ins that you have installed.
If you don’t do this and want to use LADSPA plug-ins you need to add a LADSPA_PATH environment variable, or move any repository installed LADSPA plug-ins to a location where Audacity will find them. See here for more details: http://wiki.audacityteam.org/wiki/Ladspa_Plug-ins
Before building Audacity again I’d suggest running “make distclean” which will remove both the built files and the previous configuration. Then run ./configure --prefix=/usr/
To summarise,
Remove your custom build of FFmpeg.
Install dependencies using:
Open a Terminal window in the root of the Audacity source code.
enter the following commands:
sudo make uninstall
<password>
make distclean
make
sudo make install
<password>
If you find that Audacity still does not find FFmpeg after doing this, please post the contents from Audacity “Help menu > Show Log”.
I have so much respect for the great work in FOSS Audacity, and depend on it constantly.
Steve, your suggestions were perfect. Audacity now finds the ffmpeg libs fine.
