I just installed audacity under Debian Jessie and bought a Reshow USB Cassette Player. I want to digitize my old audio cassettes over the USB (2.0) Channel. However Audacity does not provide access to that USB-channel. At least I do not find a way to connect the device to audacity.
Thank you, the problem with changing software is always: Never change a running system!
Otherwise: I will try to connect the device before launching audacity
