I recently updated to Windows 10. I found when I recorded voice over auditions, the was no audio when I replayed the voice over.
I hit the record button and a box appears on my screen
it says error while opening sound device. Please check the recording device settings and the project sample rate.
Is the anything that can be downloaded so I can get back to work. Or is there a way I can go back to Windows 8??
thank you
Patrick Foley
