I have a problem with the LADSPA Plug-Ins. I downloaded and installed them and placed the files inside the Audacity Plug In folder, restarted Audacity, but the LADSPA Plug-Ins effects still don’t work. They appear in the effects drop down menu, but when I try and use them on my vocals track, they don’t change the audio at all.
Which specific effects have you tried?
These plug-ins are rather old and not made by Audacity, so there’s no guarantee that they will all work, though most of them should.
