Audacity 2.0.4 blue screen on Windows 7
using Win7 64bit 12GB v2.0.3 works fine but 2.0.4 ends with a blue screen. Installing 2.0.4 ends with confirming using 2 plugin-DLL’s. After both enabling (default) and disabling each time I get this screen. I tried 5 times and finally reverted to v2.0.3 . Each time I completely removed everything from my PC inclusive the registry lines. Is there a solution ?
Please try the proposed solution here: https://forum.audacityteam.org/t/audacity-start-failure-or-blue-screen-on-a-few-machines/30903/1
