Audacity 1.2.5 projects compatible with 2.4.2?
Hi All,
My machine is running Mac OS 10.12.6, and I’m still on Audacity 1.2.5. I’ve got a ton of projects that are really important to me. If I update Audacity to the current version (though OS 10.12 isn’t officially supported in that version) will my files still be accessible/compatible?
It’s been a very long time since I’ve used any “1.2.x” version of Audacity, but as far as I’m aware those projects should still open in the current version of Audacity.
Because Audacity 1.2.5 is so ancient (released in 2006), I’d suggest that you try opening the least important project first. If that works, then you should be OK, but if you get problems then you could always go back to 1.2.5 or 1.2.6 (I’m sure I’ve got the original DMG somewhere if you haven’t).
