before I begin:
When I drop files into Winamp 5.666+ the files play fine after dragging and dropping. Single file, or multiple.
It is only Audacity that givesd me this error of just giving me the cirlce with the crossbar, thereby blocking my file drops.
As though it does not recognise what the files are.
I’ve tried Flaac, mp3, wav. All give same result.
The files work perfectly correctly in my music DAWs, and all my media players (currently Winamp, Traktor 2, and ableton on windows 10, and JetAudio on Android. The files are fine.
All my configurations on windows are fine (they have to be to use DAW’s well on windows).
Also, when I try to use ‘import’ and go into relevant folders, Audacity doesn;t see ANYTHING. As though the files do not exist.
For all the difference it makes. Audacity was installed via right click ‘run as admin’.
I’ve got a lot of work to do tonight, and this has now put me back four hours. (Audacity is, or certainly was, my favorate tempo changer when in a hurry making a demo. But is un-useable at the moment in this respect.)
