I LUV ME MY AUDACITY!!!
for a frustrated person of so little means…I am so THANKFULL for this resource!!
I changed from Win 7 to Win 8 and had to upgrade to Aud 2.0.5 on the new computer
all my settings gone from win 7 of course
cant get the echos out AAAaaagghhh…
trying to have 4 vocal copied lines. two are 100% right and left w/reverb
and lead and double at 30% w/delay
TOOO MUCCCHH delay/REVERB
what should be the settings? I’ve got a powerfull vocal youtube.com/girlcoversongs
cant find any recommended settings for the effects ANYWHERE for 2014!!!
THANK YOU!!!
JUST MADE A POST AN HOUR AGO AND NOW ITS GONE?? hhmmmmm
okay…WHAT OR WHERE CAN I FIND A LIST OF SETTINGS FOR THE LAME PLUG IN EFFECTS
I AM LOOOKING FOR SETTINGS TYPICAL FOR REVERB AND DELAY FOR FEMALE VOCS THRU A USB MIC WITH A STANDARD SOUND CARD
I CANNOT FIGURE OUT HOW TO DECREASE THE ECHOOOOOOO!!!
I LUV YOU AUDACITY!!! AND THANK YOU FOR YOUR HARD WORK ON BRINGING THIS WONDERFULL TOOOL 2 US!!
Moderator note: thanks for the praise and love - but please don’t SHOUT it’s considered bad netiquette …
If you’re trying self-recording, recording a YouTube video or something similar, you should probably turn off Overdubbing and Playthrough.
Audacity > Edit > Preferences > Recording > [] Overdubbing… [] Playthrough … De-select both.
Your postings are moderated by the forum elves to keep you from trying to sell us Male Enhancing Drugs. You’re not, are you?
Lame is MP3 managing software. Playing an MP3 is free, but making a new one isn’t. Lame is work-alike MP3 making software.
Audacity won’t do anything in real time. No applying reverb or echo while you’re recording a fresh track. Audacity always records a clean track. All the tools and effects are applied later in post production.
Audacity 2.0.5/Windows 8 - second version
whatever the separate add on for effects was that you load AFTER audacity, that is what is loaded
NO to all the above posted “scenarios”
I am attempting to ADD effects on 4 layers of vocals A F T E R recording, ie. during a mixdown
just want to know a good standard vocal affect setting for female gospel/soul vocals for reverb and delay…its tooo echo
Thank you for your wisdom,I luv Audacity!!!
Look here: Reverb - Audacity Manual . What is good is what sounds good to you, not to us.
Try reducing room size and reverberance.
