Asio4all Compatibility For Audacity
Hello, Good Afternoon, Everything is great, I hope so, I would like the Audacity Software in Version 4.0.0 to be compatible with Asio4all and derivatives. Ok, I would be very grateful if someone could answer this suggestion. Thank you.
ASIO4ALL adapts the hardware/drivers so that you can use an ASIO application with a regular soundcard that doesn’t come with ASIO drivers.
It doesn’t work the other way around… It doesn’t adapt non-ASIO applications to work with ASIO hardware/drivers.
From the Audacity Manual
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
