I have (after a very long time) compiled ASIO support into audacity.
I use vb-audio’s voicemeeter
It allows two mics sent via virtual ASIO with composite (splitting it across 8 channels)
The two mics are channel 3,4 (mic 1) and 5,6 (mic 2).
Now when i record in audacity with:
HOST: ASIO
INPUT: VOICEMEETER VIRTUAL ASIO
CHANNELS: 8
It records them all in mono, is there an option similar to reaper that allows you to create a track that records specific channels? Or is the only way to do it: Monitor all 8 channels cut out 1,2,7,8 then make stereo between 3,4 and 5,6?
