"Apply to files" Chain doesn't work [SOLVED]
I set a chain for Changing Pitch.
It works when I use “Apply to current project”,
but it doesn’t work when I use “Apply to files”.
I did see all files in the processing list, but the effect didn’t apply.
Any idea why?
Did you add an Export command at the end of the Chain? See: http://manual.audacityteam.org/o/man/edit_chains.html .
That’s why!!!
Thanks so much!!!
