Appimage 3.3.1 Will Not Run
Using Linux Mint 20.3
Used Appimage 3.3.0 and it ran perfectly OK but after updating to Appimage version 3.3.1 it will not open, nothing happens at all when I try to run it. Have used permissions tab to set the Execute option to ‘Allow executing file as program’ but it will still not run.
Bug is here:
Thanks for the info. Will go back to using v3.2.5 for the moment.
I have exactly the same issue.
Continuing the discussion from Appimage 3.3.1 Will Not Run:
That*s my problem too on manjaro-linux. I tried on several PCs.
I alwasys get:
[alfons@M93p-Manjaro ~]$ ‘/home/alfons/appimage/audacity-linux-3.3.1-x64.AppImage’
/usr/lib/libatk-1.0.so.0
/usr/lib/libatk-bridge-2.0.so.0
/usr/lib/libcairo-gobject.so.2
/usr/lib/libcairo.so.2
/usr/lib/libgio-2.0.so.0
/usr/lib/libglib-2.0.so.0
/usr/lib/libgmodule-2.0.so.0
/usr/lib/libgobject-2.0.so.0
/usr/lib/libgthread-2.0.so.0
/usr/lib/libjack.so.0
/usr/lib/libportaudio.so
(process:18111): Gdk-CRITICAL **: 17:53:46.936: IA__gdk_screen_get_root_window: assertion ‘GDK_IS_SCREEN (screen)’ failed
(process:18111): Gdk-CRITICAL **: 17:53:46.937: _gdk_pixmap_new: assertion ‘(drawable != NULL) || (depth != -1)’ failed
…/source_subfolder/src/gtk/bitmap.cpp(827): assert ““IsOk()”” failed in ConvertToImage(): invalid bitmap
…/source_subfolder/src/common/image.cpp(2172): assert ““IsOk()”” failed in SetMaskColour(): invalid image
…/source_subfolder/src/common/image.cpp(2223): assert ““IsOk()”” failed in SetMask(): invalid image
…/source_subfolder/src/common/image.cpp(1853): assert ““IsOk()”” failed in GetWidth(): invalid image
…/source_subfolder/src/common/image.cpp(1860): assert ““IsOk()”” failed in GetHeight(): invalid image
…/source_subfolder/src/common/image.cpp(2112): assert ““IsOk()”” failed in GetAlpha(): invalid image
…/source_subfolder/src/common/image.cpp(2232): assert ““IsOk()”” failed in HasMask(): invalid image
…/source_subfolder/src/common/image.cpp(1986): assert ““IsOk()”” failed in GetData(): invalid image
(process:18111): GdkPixbuf-CRITICAL **: 17:53:46.940: gdk_pixbuf_new_from_data: assertion ‘data != NULL’ failed
(process:18111): Gdk-CRITICAL **: 17:53:46.940: IA__gdk_screen_get_root_window: assertion ‘GDK_IS_SCREEN (screen)’ failed
(process:18111): Gdk-CRITICAL **: 17:53:46.940: IA__gdk_drawable_get_display: assertion ‘GDK_IS_DRAWABLE (drawable)’ failed
(process:18111): Gdk-CRITICAL **: 17:53:46.940: IA__gdk_cursor_new_from_pixbuf: assertion ‘GDK_IS_DISPLAY (display)’ failed
(process:18111): GLib-GObject-CRITICAL **: 17:53:46.940: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
Same with 3.3.1 AppImage here.
Fedora 38 / 6.2.14-300.fc38.x86_64
—oOo—
findlib: libportaudio.so: cannot open shared object file: No such file or directory
/home/per/Downloads/audacity-linux-3.2.5-x64.AppImage: Using fallback for library ‘libportaudio.so’
(process:9273): Gdk-CRITICAL **: 16:24:07.148: IA__gdk_screen_get_root_window: assertion ‘GDK_IS_SCREEN (screen)’ failed
(process:9273): Gdk-CRITICAL **: 16:24:07.151: gdk_pixmap_new: assertion ‘(drawable != NULL) || (depth != -1)’ failed
/home/runner/work/audacity/audacity/.conan/data/wxwidgets/3.1.3.3-audacity/
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/gtk/bitmap.cpp(827): assert ““IsOk()”” failed in ConvertToImage(): invalid bitmap
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(2172): assert ““IsOk()”” failed in SetMaskColour(): invalid image
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(2223): assert ““IsOk()”” failed in SetMask(): invalid image
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(1853): assert ““IsOk()”” failed in GetWidth(): invalid image
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(1860): assert ““IsOk()”” failed in GetHeight(): invalid image
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(2112): assert ““IsOk()”” failed in GetAlpha(): invalid image
//build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(2232): assert ““IsOk()”” failed in HasMask(): invalid image
/_/build/d0f904c49f8cdb020c221b8f0599c65e51b5eed6/source_subfolder/src/common/image.cpp(1986): assert ““IsOk()”” failed in GetData(): invalid image
(process:9273): GdkPixbuf-CRITICAL **: 16:24:07.155: gdk_pixbuf_new_from_data: assertion ‘data != NULL’ failed
(process:9273): Gdk-CRITICAL **: 16:24:07.155: IA__gdk_screen_get_root_window: assertion ‘GDK_IS_SCREEN (screen)’ failed
(process:9273): Gdk-CRITICAL **: 16:24:07.155: IA__gdk_drawable_get_display: assertion ‘GDK_IS_DRAWABLE (drawable)’ failed
(process:9273): Gdk-CRITICAL **: 16:24:07.155: IA__gdk_cursor_new_from_pixbuf: assertion ‘GDK_IS_DISPLAY (display)’ failed
(process:9273): GLib-GObject-CRITICAL **: 16:24:07.155: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
Thanks for the reports, this bug is fixed and will be made available together with 3.3.2
