Greetings.
I am digitizing a cassette tape. I reached the end of side one and paused the copy while I turned it over. I cannot figure out how to resume recording.
Thank you.
Greetings.
Thank you.
“P” to pause and “P” to start it up again.
You can also press Stop and then Append Record (Shift-R) to start it up again. Audacity will only Append Record at the end. You can’t use it for trimming or editing.
Great, Koz.
So, can I edit/clip the tail and then use Append Record? If so, can you give me a quick explanation on how to clip the tail?
Thank you.
Select the section (of tail) you don’t want using the mouse, see … https://forum.audacityteam.org/t/cut-editing-from-cassette-tapes-to-mp3/44062/4
After you have deleted the excess, you’ll probably want to apply fade-out.
