Hi — I just upgraded to a MacBook Pro running the current release of Ventura — lots of disk space and RAM and Audacity’s been running like a dream.
But today, I needed to use the Detach on Silences feature to cleanly cut up a 18 minutes recording of single words into lots of single words into individual one-word clips.
In the past, this has worked perfectly but despite the silence between clips being substantially less than .001 db, the Detach on Silence command has no effect at all. I have no idea why, even restarting the machine has not helped.
The problem is totally reproducible by simply launching the file, selecting the piece of audio and then triggering the command - nothing happens, though everything else in Audacity seems to work normally.
Is this a bug on version 3.3.3 or is there something that I can try to see if it helps the situation?
Thanks
Allan
