Any way to playback different track on different Output?
Hi
I have a wav file include 6 tracks
Is that any way to play track 1 on output device 1, track 2 on output device 2…?
Audacity can only use one device at a time, and as I recall, playback is only stereo.
It might be possible to use Voicemeeter or Banana from http://vb-audio.pagesperso-orange.fr/Voicemeeter/index.htm as the Audacity playback device then route the channels to your separate devices. I don’t know - you would have to try it. You can get support from the author of those applications.
