I often find a need to move tracks up and down, such as when synchronizing (compare the spikes in a drum track with those in another rhythm part); but the process is laborious in a large, multitrack project. Is there a way to quickly drag a track up and down or a command to re-order the tracks?
Try “View menu > Collapse all tracks” (CTRL+shift+C) before you start dragging.
Thank you,
