I just installed Audacity 2.0.5 for the first time on my Mac. I tried to install the OS X version of a VST plug-in (Anwida Soft DX Reverb Light) according to the instructions here, http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#vst_install, but found that the plug-in did not show up in the Effects menu even after I followed all the steps.
I didn’t have this problem when I used Audacity on my PC, as I installed the Windows version of the same plug-in without any hitches (it showed up in the Effects menu). Am wondering if this problem has anything to do with the latest version of Audacity only, because if I’m not wrong the version on my PC might be an older one.
Any help would be much appreciated.
