another question
hi
i have 2 questions 4 u to ponder…i just tried to play and record using my new soundcard(i managed to fix it)anyway when i played it back i noticed the recording had echoing and i did nothing to produce it…is this something in audicity that needs
attention?also…when i tried to play and record this tune i noticed that i could not contril the output level meters could not
be controled by the mike input on the left…even with them up to maximum i still didnt get the output meters into the red.
its as though they are being controlled for me by this new soundcard.i had no trouble with them when i had the old on board
audio player working.is there anything i can do?thanks.
lenny
ps i hope i made myself clear…
What is your new sound card? Is it an internal or external sound card?
hi
internal
lenny
And do you know what sort it is? (manufacturer/model number)
hi
thanks but i found my answer elseware…
lenny
You might have got an answer sooner if you had given enough information in your initial question.
no problem…
